Help with MEVI RPM switch
Ok, I have the mevi installed and all the vaccums hooked up and everything else except for the rpm signal wire (white wire on rpm switch) I have heard its a white wire with a green stripe on the ecu harness anyone know this
thanks Brandon
thanks Brandon
Originally Posted by 95stillenmax
ok I talked to jamie and he just use a coil pack, so i did and now when I hook the rpm switch to the battery the MEVI just opens automaticly, why is this?
![](https://maxima.org/forums/images/smilies/support.gif)
I am have the summit rpm switch and I used the third multicolored wire
You can't use the coil pack with the summit. You have to use the tach signal from the ECU. It is the white wire with a green stripe. Kinda hard to find. Your best bet is undo the bundle of wires going into the ECU, tap the tach signal, and rebundle up the wires. IIRC the tach wire is next to a couple of purple wires and one empty pin.
The summit switch will also have one unused wire, the grey one I believe. So you have the power (I use the cig fuse), groud, tach, and wire for the daws switch.
And remeber, you can't set the summit dip switches like the harlan. It's not made for a 6cyl so you kinda have to guess where to set it. 3200 or 3400 on the dip switches works for me.
oh...I30mikeD is it hard to set the rpm switch you think you could explain how to
thanks Brandon
thanks Brandon
Have you looked at how to do it yet? It's so easy I can't imagine you tired to do it and had problems. You just move the dip switches the desried rpm
As far as what to set it at you just need to try different ones and see what works for you. It might be different than what I use. You want it to open around 5200-5400 rpm's indicated on your tach. Just mess with the dip switches unitl you get it to open at that point.
![bonk](https://maxima.org/forums/images/smilies/bonk.gif)
litch
123
01-04-2024 07:01 PM
HerpDerp1919
09-29-2015 02:02 PM
