Pittsburgh spring compressors - any experiences?
Old May 3, 2004 | 09:10 AM
Neif's Avatar
Im thinking about buying these Pittsburgh spring compressors,
http://www.harborfreight.com/cpi/cta...temnumber=3980
but I'm a little wary about the cheap price. Does anyone have any experiences, good or bad, with these compressors? The Sears ones are $30 more, so I'm wondering if there really is a quality difference.
Old May 3, 2004 | 09:31 AM
GodsmackMAX's Avatar
Can't you just go to your local autoparts store and rent one?
drew
Old May 3, 2004 | 11:21 AM
Neif's Avatar
The one that NAPA had was also a Pittsburgh, and our Kragen doesn't rent em. Also its $15 a day so not really worth the rental if I can buy it for cheaper. What brands do you use?
Old May 3, 2004 | 12:02 PM
Brudaddy's Avatar
All I know is that every Pittsburg tool that I have used is pretty high quality. I don't know about the compressors, but I have some other tools that are very well made.
Old May 3, 2004 | 01:25 PM
Mishmosh's Avatar
They are heavy duty and get the job done quick (if you have a air impact wrench). Not worth spending a lot of dough on a part you may only use once. I think Autozone has free rentals though.
Old May 3, 2004 | 01:34 PM
Ladzio's Avatar
In my town Autozone almost does not rent stuff anymore, they used to... I am thinking about getting those too...
Old May 3, 2004 | 03:22 PM
Neif's Avatar
Are they workable without air tools?
Old May 3, 2004 | 03:34 PM
Mishmosh's Avatar
Definitely. The tool has two sides you have to wrench alternately. Just takes a while for all 4 corners. I believe the socket you'll need is fairly large though...not something in your typical 3/8" socket set but maybe in a 1/2" set. Sorry, I forget what it was. Before I bought my air tools, I used the Pittsburgh to drop my car using hand tools. It took a while.... a LONG while.
At least if you put on lowering springs, the compressors aren't needed so that really helps when putting the springs/strut-shock assemblies back together.
Old May 3, 2004 | 03:41 PM
MDeezy's Avatar
are they?
thats what I would like to know as well.
Old May 3, 2004 | 03:48 PM
RA030726's Avatar
I'm nutty for Nissans
I have similar ones from VIP and they work fine without air tools. I use my drill on it though.....its a 12 volt DeWalt with like 360 inlbs of tourque, yes thats like 30 ftlbs, but it helps. Its soooooo boring tightening the compressor with a ratchet. Anyway these compressors you are looking at will work great, just plan on buying the needed 15/16" socket for your ratchet.
Old May 3, 2004 | 03:54 PM
Neif's Avatar
Here's the pdf manual for the compressors -
http://www.harborfreight.com/manuals/3000-3999/3980.pdf
It seems fairly time consuming, and has alot of extra parts to put in it - whereas the Sears Craftsman one seems alot simpler, i think all the extra clamps and parts are built in.
Old May 4, 2004 | 08:53 AM
Neif's Avatar
Ok, I ordered the Pittsburgh ones (10$ extra shipping and handling) came to $20. I hope they're not too hard to use!
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
Pied
Sep 26, 2015 03:29 PM
