tranny question
assuming your automatic, probably the shift cable snagging/rubbing/ hitting on something behind the dash. under the shift trim area
Other guess is that when you shift it to reverse, your engine will rock and might sometimes rub against something like a FSTB or other things making a pop or clunk/click noise.
It could be your shift lock clicking. You could pull the plastic cover off around the shifter and get easy access to it. It's on the lower right. If you have spilled any drinks in there that would might it stick. It's pretty easy to clean.
Unclejunebug
Apr 2, 2016 05:42 AM
pktaske
Sep 4, 2015 08:40 AM
