Oh Great gods Of Maxima.Org Hear My Plea!!!!!!!!!!!!!
a couple of days ago i took alittle trip driving the max. everthing was wonderful i took the truck route down the turnpike so that easily pass buy trucks and let the sexy best do her thing.
anyway after i returned from my trip i noticed the next when i drove my car the oil light would flicker on and off. i changed the oil switch in case that was it, but it wasnt. the light still flickers.
and one out there have any input on this or have had the same problem????????
hate to ask this again...but did you check ur oil after the car has sat overnight?
These motors are a major PITA to check oil level after the motor hasn't sat for over 3 hours. If you let it sit for say atleast an hour...you still gotta pull the dipstick and clean many times to get a clean reading of where the oil level is at. And even after doing that...you have to mentally adjust your reading because not all of the oil has dropped into the pan (so it reads lower than you see it at).
I believe Nissan put out a Service Bulletin to get that replaced cause it leaks....when I first got my car that was the first reason my CEL came on and even though my light didn't flicker it fixed the CEL so mostly likely that is the only reason why it is flickering...they are problemsome...... <<<---(is that a word)?
Originally Posted by Maxima95Tuner
Oil Pressure Sending Unit. Light flickered on and off for me too, with no code. Turned out to be this part. Have it looked at.
boomerbrian
Oct 31, 2018 10:25 AM
