? about brake pad wear
Old May 8, 2004 | 06:47 PM
Pearl99GXE's Avatar
When I changed my front pads today, I noticed that the pasenger side brakes had worn twice as much as the driver side. Shouldn't they wear equally? I know the fronts wear faster than the backs. Is there something that needs to be adjusted?
The previous owner had the pads replaced right before he sold it to me. That is why I changed the rotors while I was at it.
Old May 8, 2004 | 06:52 PM
95GreekMaxSE's Avatar
The ones that are wearing the quckest (passenger side in your case) more then likely is sticking a little bit when you apply the brakes thus making contact with the rotor longer. Get the pins on the calipers re-greased.
Old May 10, 2004 | 09:26 AM
Brudaddy's Avatar
yeah, check out that caliper that is ont he side that is wearing more. It might be sticking a little.
Greasing it should do the thing.
Old May 10, 2004 | 09:36 AM
MrEous's Avatar
^ Jeff™
...and make sure the caliper is fully bolted to the hub...
lol
Old May 10, 2004 | 09:37 AM
Jeff92se's Avatar
I'm needing a caw
Inspect that caliper to see that the wheel moves somewhat freely when turned. Also consider lubricating the slide pins and the areas that each side of the brake pad rides on inside the caliper housing. If something is binding, it will not allow the pad to retract back from the rotor
Old May 10, 2004 | 09:49 AM
Pearl99GXE's Avatar
That side was a ***** to get the bolts off. The pads bolt were tight and the bracket bolts were very tight I had to stand on the wrench to get it to break loose. When I put it all together, I used plenty of grease on the pad pins and some anti seize on the caliper bolts. As for the calier housings I cleaned with a rag to get all of the old break dust off. I never thought about putting grease on them. Great Idea.
Hopefully that should cure that problem.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
