fog lights keep blowing fuse
Old May 10, 2004 | 07:28 PM
SiMpLyMaXedOuT's Avatar
sup guys..i was wondering if any of yous came accross this issue
i rewired my 4th gen clearence lights to make them brighter and also ahve my stock fog lights wired to come on without the headlights necessarily being on
recently every time i mess with my fog lights turning off/on..the fuse blows for the fogs...then i replaced the fuse....n turned the fogs on/off for a while and then the corner clearance light bulb blew...
i checked teh wiring it seems to be ok..
also these fogs were put on by the dealer few yrs ago... its a gxe max so they did their own wiring since they didnt have any plug/play harness to fit stock fogts into the car back in 99
any idea of what could be causing the problem? i've had my clearance lights rewired for more than a yr as well as my fogs..this just started to happen recently
any help would b appreciated
Old May 10, 2004 | 09:49 PM
Nick7455's Avatar
Did you just twist the wires together, solder them or did you use those press and clamp thingys? I just did this mod this weekend and after blowing fuses a few months back cause of my fogs I have done fine the past few days.....
Old May 11, 2004 | 10:19 AM
i just crimped the wires...still regardless. i checked those connections..n they're fine
i pulled em and moved them around...no flickering of the lights so the connections r tight
Old May 11, 2004 | 10:50 AM
96white's Avatar
had the same problem on my friends SE-L , he had the wires in the wrong place, the bulbs would work for a second then blow the fuse.
Old May 11, 2004 | 11:57 AM
wrong place? what do u mean
The Frye
Sep 2, 2021 11:03 AM
pktaske
May 6, 2016 07:49 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
pktaske
Sep 4, 2015 08:40 AM
mikebla
Sep 3, 2015 05:37 PM
