Tint Removal ?
Old May 11, 2004 | 05:40 AM
Klockpurple's Avatar
Tint Removal ?
Has anyone on the org. ever try using a heat gun to remove tint ? How does it work ?
Old May 11, 2004 | 05:50 AM
jmeister's Avatar
I bought some stuff from Autozone called Gila Tint Remover. Comes in a spray bottle with a plastic scraper. Tells how much it will remove per bottle, only like $8. Friend had good luck with it, I haven't had a chance to try it yet myself.
Old May 11, 2004 | 06:30 AM
belosic's Avatar
If it's a warm sunny day outside, and you don't mind sweating inside your car, you can let it sit in the sun to heat the tint and you won't need a heat gun. I did mine that way, pretty easy, just make sure you have some cold beer close by.
Old May 11, 2004 | 06:49 AM
juani's Avatar
Rockin' VK56!!
I gotta do this too. My tint on rear window is getting worse everyday.
any instruction or advise?
-John
Old May 11, 2004 | 06:59 AM
belosic's Avatar
Advise- Don't use a sharp razor blade, you could permanently damage the glass, especially the rear defroster. Get the glass nice and hot, the tint will come off in bigger pieces that way.
Old May 11, 2004 | 07:45 AM
Brudaddy's Avatar
There are some other threads for this. You just have to make sure to take your time with the rear window. If you don't, you can say bye, bye to your rear defroster.
That is the only reason I have not tackled mine yet.
It is doable though, just takes some elbow grease.
Old May 11, 2004 | 10:29 AM
minsbang's Avatar
to remove tints, i used:
Windex
Razor blade
Paper Towel
I have removed tints for atleast 5 cars and they all came out nice.
Old May 11, 2004 | 10:55 AM
Brudaddy's Avatar
yes, but you cannot use razor on rear glass if you have a rear defroster. You will ruin it.
Old May 11, 2004 | 12:57 PM
ilyaat's Avatar
...why would you want to get rid of it??
Old May 11, 2004 | 02:29 PM
burgundyblues66's Avatar
when i look in my rear view mirror through my tint it looks like looking through somebodys prescription glasses. I want to take it off but then again, i want to have tint in the back. if i installed new do-it-myself tint would it look completely clear? Im still going to take it off first because i cant even tell what kind of car is behind me, bad idea because of cops. anyway, how easy is it to install store bought tint?
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
