How Do You Remove The Door Trim?
Old May 12, 2004 | 08:46 AM
nookiecrook's Avatar
I was just wondering if any one knows how to remove the door trim/molding on the 4th gen.?
Old May 12, 2004 | 08:57 AM
Nismo's Avatar
you gotta pry them off because there are holes in the door that the molding things stick into
Old May 12, 2004 | 03:36 PM
1991tsi's Avatar
pull the trim around the handle off, theres a screw under a cap at the bottom of the hole in the armrest, pry out the window switch, then gently unseat the christmas tree clips that hold the panel to the door, starting from the bottom. When they're all out, hold the panel with the bottom away from the door and pull straight up to get the top out of the sill.
Old May 12, 2004 | 11:34 PM
Nismo's Avatar
I think he was trying to get the door moldings off, instead of the door panel
Old May 13, 2004 | 07:46 PM
1991tsi's Avatar
my bad, it was a pretty crappy explanation anyhow...
Old May 19, 2004 | 09:24 PM
Yeah, I was talking about the outside trim, was'nt sure if it was stuck with adhesive tape or if it left holes when removed?
Old May 19, 2004 | 09:50 PM
volkl77's Avatar
Remove the OUTside trim from the INside of the door. This requires removing the inner panel as 1991tsi explained... and peeling away the plastic vapor barrier... then you will see the backside of the clips holding the trim to the door....
Cheers!
James92SE
142
Jan 2, 2024 09:23 AM
The Frye
Feb 3, 2019 08:34 AM
ef9
Sep 29, 2015 11:29 PM
carid
Sep 17, 2015 05:00 AM
brichi
Sep 14, 2015 05:23 PM
