Installation of an Amp/Sub to stock bose sound system
Old May 12, 2004 | 02:19 PM
yeehawtex's Avatar
HI,
I have a 97 max gle, with the stock bose sound system. I would like to keep my stock bose head unit as well as the speakers. I'd like to add some bass by adding an amp and a 12" sub. I've heard conflicting theories on whether one can install aftermarket amps/subs to a stock bose system. I know that the bose system is a little different in the fact that it has amps at each speaker. Basically my concern is that if I do install an amp/sub with a line out converter or some other approach it may ruin my stock system in the long run. The last thing i want is my stock bose system to die on me for adding the amp/sub.
Is it possible to install an amp/sub with stock bose speakers/deck and if so what is the procedure? How does it sound? Does anyone have an existing setup that is kinda like how i want mine?
Some have suggested that it can't be done, others say use special nissan bose adapters, others still say use a line out converter? I'm kinda confused and not sure who to believe?
I would really appreciate it if you could let me know your thoughts.
Thanks,
Old May 12, 2004 | 02:50 PM
nitromax's Avatar
you can add the amp & subs , but you do need to get the adapter , and probably a noise filter. if you DIY check with Crutchfield stereo for parts and advice, if you have it done Best Buy can do it, but ask questions ie: whose done it, what problems if any, recommendations.
Old May 12, 2004 | 03:14 PM
Flava_24/7's Avatar
Boosted Panda
hjere you go.... http://forums.maxima.org/showthread.php?t=308700
yeehawtex
I see your in Austin.
Check this link...... http://forums.maxima.org/showthread....0&page=2&pp=30
JRod28
Dec 29, 2023 09:56 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Abdelrhman
Aug 17, 2015 12:16 PM
