low idle and ticking noise
Old May 12, 2004 | 10:22 PM
masterB's Avatar
HELP!! the ECU is giving me 0505 which means nothing is wrong, but my car is idling at very low rpm??
also, when the key is truned to ON without the engine running. i could hear a ticking noise under the hood. it ticks at a very steady speed, sounds like a clock ticking inside the engine.
Does anyone know what's wrong with my 96 se and how to fix the problems??
Thank you in advance.
Old May 13, 2004 | 01:53 AM
Prophecy1's Avatar
Ticking?
Usually sticky valves.
Most user higher quality gas and higher quality oil and seems to solve the issue.
As for the Idel, Id suggest resetting the ECU.
Proph
Old May 13, 2004 | 02:31 AM
njmaxseltd's Avatar
The ticking your hearing is the Idle Air Control Valve. It's normal to hear that device tick even if your engine isn't running.
Clean your throttle body, goto www.motorvate.ca for instructions or just search around for instructions here in the forums. If that doesn't fix your low idle, adjust it. I believe instructions for that are also on motorvate.
Old May 13, 2004 | 06:39 AM
meanbean's Avatar
Also, try running 1/2 can of Seafoam through your brake booster. Should smooth out your idle.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
