Brian V Mod AND y-PIPE
Old Mar 25, 2001 | 10:30 AM
totochilla's Avatar
so far i haven't done any intake or exhaust mods, im reading all the posts and seeing whass hot. First off, from what i know the y-pipe is better than a CAI??? RIGHT??
so i figure ill do the cheap intake so i can get a y-pipe.
what u guys think??
ohh yeah and can someone send me good link for the intake mod??
Old Mar 25, 2001 | 10:44 AM
metallic97gxe's Avatar
Master Will
all you do it take the factory airbox off then put on a intake adapter on the throttle body and put on a 3" opening cone filter and then you are done...I was told to disconnect the battery for two hours to let the computer reset itself and I did it and it is fine...you need to get the intake beacaue you will have more air going into the engine so more needs to come out...so get the y-pipe for a real good combination...
Old Mar 25, 2001 | 05:33 PM
BrianV's Avatar
the computer WILL not reset by disconnecting the battery;
for any amount of time. Follow the correct instructions:
http://www.brianv.net/ecu.html
Intake Mod Link
http://www.brianv.net/filter.html
Old Mar 25, 2001 | 05:44 PM
Master Will
Intake Mod Link
look at this......resettting computer....I guess Jeff K is wrong then huh!!!!!!!!
http://integra.vtec.net/geeser/megamax/intake.html
Old Mar 25, 2001 | 11:33 PM
BrianV's Avatar
Daniel B. Martin!
Please tell me if I'm correct by saying simply disconnecting the battery WILL NOT reset the ECU.
Old Mar 26, 2001 | 05:31 AM
Sprint's Avatar
Disconnecting the battery for 24 hours will reset the ECU
Daniel B. Martin!
Old Mar 26, 2001 | 12:57 PM
BrianV's Avatar
I'll believe that because there's a short term memory, and without power it can only last for a certain extended time. However, it's inpracticle to leave it off for 24 hours.
Quickywd01
Sep 21, 2016 09:36 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
