Air bag light flashing
Old May 13, 2004 | 07:29 PM
ibrahimekawi's Avatar
Anyone know how to get rid of it or reset it.....i had this problem when i got the car, so i took it to an air bad specialist and he got rid of it ...but charged me a couple of hundred bucks....so im sure it's nothing more that a stupid reset thing...any one help!!!
Old May 16, 2004 | 08:21 PM
No one knows?
Your telling me nobody knows about this problem?
Old May 16, 2004 | 08:28 PM
Nick7455's Avatar
Listen very carefully as the directions in the HOW TO's ( GO THERE OFTEN KID) is slightly wrong.......
First go to your car and leave your door open...on pillar B you will see a button covered with rubber...that is the Driver's door switch (DDS) and this is what makes the car know when the door is closed. This is actually on the car itself and not on the door...anyways with the door OPEN put your key in the ignition and turn it to ACC.....then press that rubber button about 6-8 times within 10 secs and then TURN THE KEY BETWEEN LOCK (0) and ON (2). Now close the door and start the car. This should clear up the light!
Old May 16, 2004 | 08:29 PM
Nick7455's Avatar
Go do this right now and come right back and post what happened.......
Old May 17, 2004 | 06:25 AM
It didn't work
I tried it and it didn't work....i know how to get the fault codes out of it....and it gave me a short signal then two long ones!!! any one how to read the fault codes....or know how to reset the air bag light please let me know...thnx
Old May 17, 2004 | 07:04 AM
Terran's Avatar
http://vbxmaxima.8m.com/ecudecoder.html
0201=Ignition Signal Circuit
Old May 17, 2004 | 07:10 AM
Wrong One
This one is for the check engine light not the airbag light!!!!
I need help, anyone please that airbag light is anoying!!!!
Old May 17, 2004 | 07:39 AM
Terran's Avatar
Oh, I didn't even know the airbag light could give codes. heres the directions from the faqs:
"How to reset SRS(air bag) light –
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer."
If this doesn't work either, it looks like you've got to go to the dealer.
Old May 17, 2004 | 07:44 AM
Iqb316's Avatar
The directions on the FAQ/How To is a little off. Jump over to this thread http://forums.maxima.org/showthread.php?t=309090
Near the end, there's instructions on how to properly reset the light. I used it and it worked for me!
Old May 17, 2004 | 09:08 AM
Socrates's Avatar
Do the reset twice. If it goes back to flashing then there is something wrong. It's an extrememly sensitive system. What always sets mine off is things under the driver or passenger seat. Because of those damn backseat airbags. So I always reach my hand under the seats and make sure all the connections are really tight and then reset the light again and it always clears up.
Old May 17, 2004 | 05:14 PM
Light still on
This light is ****ing me off....i don't know why but i still can't get it to shut off...i tried to do those steps like 20 times....same thing...still flashing.....im sure there is another way....anyone? help!!!
Old May 18, 2004 | 07:10 AM
Fixed the problem
Ok here it is boys....it was my passenger side, side airbag. I played with the wire and then reset it...and the light is now offf.....i think maxima should deffinetly recall those side airbags for the passenger...i wish we can do something about it.....anyways im happy ...anyone need any help with their let me know...others thanx everybody
Old May 18, 2004 | 07:44 AM
Iqb316's Avatar
Just curious, which wire were you fiddling with exactly (if you can describe it?)
Old May 18, 2004 | 07:47 AM
passenger seat
if you look at the side of the passenger seat u should be able to see a wire black, and just move it around, i barely touched it....and then reset it.....and the light went off...what a relief!!!
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
