Help with this mod please??
Old May 14, 2004 | 10:08 AM
nupemaxima's Avatar
I am doing the mod that allows a buzzer to sound when I press the factory keyless entry. I'm not sure as to how the extra relay is connected. Can anyone explain this to me? I purchased the exact relay and buzzer from radio shack as the ones in the "how to" section. Unless I cant read, I saw no reference to how to connect the relay...just the power and ground from the buzzer. Any help guys
thanks
Percy
Old May 14, 2004 | 10:49 AM
nupemaxima's Avatar
Guys any help??
Old May 14, 2004 | 11:46 AM
acj's Avatar
acj
I did this mod on my car and you do not need the extra relay. All you need to do is to tie the red and black wires into the orange/green and orange wire (I cant remember which goes where, but Ill look at mine in a few minutes)
Old May 14, 2004 | 11:47 AM
nupemaxima's Avatar
Thanks alot acj
Old May 14, 2004 | 11:52 AM
acj's Avatar
acj
Just hook the red wire from the buzzer onto the Green/Orange wire and then tie the black wire onto the Orange wire.
I tried to use the relay but ended up melting one of the prongs off, so I just did it the way I described above.
And you'll be better off mounting the buzzer outside of your car, under the rear bumper. It sounds a lot louder than when its inside the trunk.
Hope this helps,
Adam
Old May 14, 2004 | 12:16 PM
nupemaxima's Avatar
acj...you saved the day!! lol! I should be a rapper. Thanks for the help bro.
Percy
Old May 14, 2004 | 12:58 PM
sadice's Avatar
acj does it sound when u turn ur blinkers or the hazards on?? cause thats what the relay is for. i tried to do ith through the realy just burned 3 fuses and stopped trying.... if without the relay it just sounds when the alarm is armed and never otehr wise than i'll do oit today please respond thanx..
Old May 14, 2004 | 02:25 PM
sadice's Avatar
ok did it already everything works great thanx a lot ajc......... now glass and shock sensors next....
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
