Blower/Fan Speed Problem
Old May 17, 2004 | 07:05 AM
gaios1's Avatar
Hoping you guys can help me out with a switch/blower problem that I'm having.
Problem:
Blower/fan only operates at highest speed, which is #4.
Symptoms:
Turning the fan/blower speed selector to 1, 2, or 3 fails to start the fan. As mentioned above, the blower only works on the highest setting.
If I depress the AC button followed by turning the blower selector switch to either 1, 2, or 3, I can immediately hear the AC come ON -- but no blower!
I removed the blower assembly and everything looks OK mechanically wise. There are (2) wires going to the blower, and (1) of those wires has constant 12VDC.
I also removed the switch assembly, but couldn't really determine if that is the cause of the problem (since the AC comes ON). There were (5) or (6) wires of different thicknesses going to the switch, and (1) of those also had constant 12VDC. Turning the selector switch to any speed dis not carry any voltage to any particular output wire.
I was wondering if anyone has had a similar problem or even heard of a similar problem.
My wife uses the MAX for my 1-year old son. Specially with the hot weather coming, it's really important that I find a solution for this very soon! I'd hate to go to Nissan for something like this... but I may have to!!
Hope you guys can help me out... any suggestions welcomed!
I'm currently at work, so I don't have a chance to troubleshoot the Max right now...
Thanks to all!
Peter
Old May 17, 2004 | 07:20 AM
Pearl99GXE's Avatar
You have a bad resister. On my 96 Sentra it was behind the glove box. I don't know where it on the Max, probably in the same area.
Old May 17, 2004 | 07:27 AM
Terran's Avatar
I'm pretty sure it's in the faqs.
Old May 17, 2004 | 08:07 AM
SonicDust187's Avatar
It is, its a $35-40 part that is under the glove box. Check FAQ.
Old May 17, 2004 | 09:46 AM
gaios1's Avatar
Thanks guys!!
I just found the FAQ:
"Why does my A/C only work on fan speed 4?"
Just called the dealer, and they tell me it's $42CAN.
Part#:27150-2J000
I'll replace it tonight!!
Thanks Again to all...
Mar 12, 2020 12:06 AM
Max139617
Oct 19, 2016 11:34 AM
lux97Max
Sep 11, 2015 01:12 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Max139617
Sep 6, 2015 06:02 PM
