Funny noise coming from front struts
Old May 17, 2004 | 05:27 PM
LIMaxin
Well my front struts are making a squeeking noise and other times making a kind of metal rattling sound (sounds like springs aren't tight).
The bolts under the hood are sitting totally inward and looks like it rubs against the rubber bushing when i push down on the car. I have GR2s in the front w/ sprint springs. Im not familiar w/ camber adjustment kits or anything, i was wondering if thats what i need.
Old May 17, 2004 | 06:00 PM
maximus_pr's Avatar
thats the strut mounts for what you describe they are very bad my advice is to replace them along with the bearing with oem don't use kyb mounts they are crap also check the rest of your suspension like ball joints control arms bushings sway bar bushings and end links and take yor car for alignmnet also check your tires for abnormal wear
Old May 17, 2004 | 06:11 PM
LIMaxin
So i should just find a pair of stock struts and replace the kyb mount with the oem mount?
Old May 17, 2004 | 11:07 PM
maximus_pr's Avatar
just the mounts if thats the case but like i said before check everything but if you happen to have the kyb mounts most likely the are wasted as for the struts i have agx on mine they are very ggod
Old May 18, 2004 | 02:47 AM
LIMaxin
ya i got agxs in the back and gr2s in the front. So the bolt should sit in the middle?
Hondarydr
Dec 30, 2024 06:15 PM
kingw323
20
Oct 21, 2015 08:36 AM
MaxStock
Aug 14, 2015 10:01 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
