Something weird happening?!
Old May 17, 2004 | 08:25 PM
_ck69_'s Avatar
I was playing with my car, trying to fix one of many problems. I started the engine and everything seemed fine until... I turned on the headlights. The engine was idling at 1000/RPM (engine was cold), and when I turned the lights on the needle suddenly dropped to 900/RPM. WTF!? I've never seen this happen before. Is this normal? Or do I have to include this on my to-do list.
Old May 17, 2004 | 08:36 PM
DAVE Sz's Avatar
Hooooooonda.....
It's normal since the lights draw power from the alternator. Since the car was still cold it went up a 100 rpm insted of 50 or so.
Old May 17, 2004 | 08:45 PM
_ck69_'s Avatar
Thanks. That's one less thing I have to worry about. Now if only I can get the car to start ALL the time.
Old May 17, 2004 | 08:47 PM
DAVE Sz's Avatar
Hooooooonda.....
Starter? Weak ignition signal? Loose wire? Fuse?
Old May 17, 2004 | 09:14 PM
Linkage23's Avatar
to fix this problem a little better than it is now, re-ground your electronics using thicker gauge wires, i.e. 4-8 gauge. This is said to also give you about 8 hp. I think I saw something on the forum regarding this....hope this helps.
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
