Error Code, need assistance please.
Old May 18, 2004 | 05:59 AM
giomontini's Avatar
Hi guys, just want to know if anyone has come across an error code of 0307 which is the Closed Loop Control?
Thanks!
Old May 18, 2004 | 01:36 PM
Kevlo911's Avatar
Kevlo for President
0307
Diagnostic Trouble Code 0307 points to a problem with the Engine Control Module Closed Loop Logic for the Left Bank. The left cylinder bank is also called the front bank. It is cylinders 2,4,6.
DTC 0307 is detected when the closed loop control function for the left bank does not operate even when the vehicle conditions meet the criteria (engine at normal operating temperature, etc.). Possible causes include ...
- Harness or connectors (The sensor circuit is open or shorted.)
- a defective Front Heated Oxygen Sensor sensing element.
- a defective Front Heated Oxygen Sensor heater.
Old May 19, 2004 | 03:35 AM
giomontini's Avatar
Originally Posted by kevlo911
0307
Thanks very much for the reply, this helps a lot. Just one other thing I need to ask you about this. I had the Front Sensor, including all the wires replaced very recently, and now I would have to check them again. But my question would be is it correct to assume that the Front Heated O2 Sensor Left Bank is the one closest to the engine? Driver's side? And the Right Bank Sensor is at the Passenger's side near and before the cat? Again, thanks very much for the help.
gio
Old May 19, 2004 | 04:10 AM
njmodi's Avatar
Do I get a tax break?
Here is a pic showing the location of the two front O2 sensors and which is considered RIGHT and LEFT.
http://www.courtesyparts.com/A32_O2-sensors.html
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
