Side/Corner marker problem
Old May 19, 2004 | 06:36 PM
Maxin It's Avatar
If one of the corner light goes out (rear left tail bulb), does all the lights go dark or just the bulb that's broken? Now the front 2 corner nor the right rear tail bulbs light up when i turn on the side markers. BTW i checked the fuse for the tail lamp and it seems fine. The element between the fuse is still good when i pulled it out.
Thanks for your help if u can!
Old May 19, 2004 | 06:41 PM
metallic97gxe's Avatar
Master Will
that bad bulb can cause the rest of the lights not to work..
Old May 19, 2004 | 07:35 PM
DAVE Sz's Avatar
Hooooooonda.....
Most likely. Also check your fuses, all the electrical fuses not just the one. Always check fuses when it's an electrical problem.
Old May 19, 2004 | 08:02 PM
Maxin It's Avatar
Everything else works fine: turn signal, headlights, brake lights, reverse lights. So i don't think any of those fuses are bad. Only problem is that none of the side markers work. There's a fuse for the front corners? i didn't see it in the fuse box. Yes i consulted the Haynes manual... it was no help
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
