Got 2 codes: 0510 and 0707 - question!!
Old May 20, 2004 | 05:05 PM
Boznian's Avatar
- Yeah, finally pulled my codes and it reads: 0510 and 0707. The Haynes manual says that those codes mean:
- 0510 : Downstream O2 sensor maximum voltage monitor fault
- 0707 : Downstream O2 sensor circuit slow response fault
- Would I fix the problem buy replacing the sensors or is the problem somewhere else? I'm about to order some sensors from www.oxygensensors.com, but before I do, I just wanna make sure whether the problem will be fixed by just replacing the sensors!!
Thanks in advance!
- Boz
Old May 20, 2004 | 05:25 PM
maximomo's Avatar
Thanks in advance!
- Boz
It's the sensors!
It's actually just the rear (downstream) sensor I believe.
Old May 20, 2004 | 05:28 PM
catalinoiu's Avatar
I had the same codes and I replaced them both (I have 2 downstream O2 sensors, CA emissions). My car has 115k and I'm replacing the other 2 as well. I spent $377 for these 4 sensors.
It is recommended to replace them around 100k anyway.
Good luck.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
