Help, code 05 05 AS SOON AS POSSIBLE, Please
Old May 22, 2004 | 12:18 PM
CKOTuHA's Avatar
I got a code 05 05, diagnose says that its not defined.
After that code, my car barelly starts up and rpms jump around. Sometimes they delay. Transmission shifts fine.
WHat could it be? Help
Thanks for any help
Old May 22, 2004 | 12:24 PM
Kevlo911's Avatar
Kevlo for President
Reset the ECU propery.
Old May 22, 2004 | 12:30 PM
CKOTuHA's Avatar
I did reset the ECU, car still doesn't start wright could it be the air sensor or emisions sensor
Old May 22, 2004 | 12:32 PM
BLAZIN's Avatar
i believe code 05 05 is the air intake temp sensor...though i never remember having any car trouble when i i pulled the code...its very likely that i am wrong, however if i was you i would still make sure that its plugged in properly...if you have stock intake it is located on the snorkel looking thing towards your resonator
BLAZIN's Avatar
emissions sensor wouldnt give you car trouble....its intake related
Old May 22, 2004 | 12:39 PM
z-dan's Avatar
Are you sure you got 05 05 cause accourding to this: http://vbxmaxima.8m.com/ecudecoder.html
it means "No Failure Recorded/Detected"
Old May 22, 2004 | 12:57 PM
Vyrus's Avatar
05 05 means that the ECU detects nothing wrong with your car. Now obviously something is wrong, but it must not be something that affects the electrical system or can be detected by the ECU.
-Cyrus
Old May 22, 2004 | 01:44 PM
CKOTuHA's Avatar
Now I got codes 03 04 and 02 15....could that be related? What should i do?
Old May 22, 2004 | 01:45 PM
CKOTuHA's Avatar
Yes i did it according to this
Old May 22, 2004 | 01:46 PM
VQvroom's Avatar
what did you do to the car?
Old May 22, 2004 | 01:50 PM
CKOTuHA's Avatar
Nothing actually, just driving it on the highway and the light went on. The next day it was difficult to start it.
Old May 22, 2004 | 01:59 PM
Vyrus's Avatar
Well that means you need to replace your knock sensor, but that shouldn't affect starting the car. I couldn't find 02 15, but I'm betting that is your major problem.
-Cyrus
Old May 22, 2004 | 02:03 PM
Jay93SE's Avatar
0304 is the knock sensor. 0215 doesn't exist! Are you sure it wasn't 0115? Problem with right bank fuel management system. Read the stickies!
Old May 22, 2004 | 11:58 PM
CKOTuHA's Avatar
I reseted ECU twice. After starting the car second time, a couple of minutes later the same codes came up. I'm positive that it was 02 15, because I wasn't the only one who was counting it.
The car drives fine, doesn't make any noise. RPMs act really weird though. Sometimes with delay, sometimes they jump up really fast after apllying barely any gas, and they drop down fast too after just letting of the gas w/o braking. It's hard to explain, but I know my Max well to see that there is something wrong.
What are the symptoms of knocking sensor going bad? Could that reflect it?
Old May 23, 2004 | 12:05 AM
meccanoble's Avatar
Sports Button FTW
not sure if this can affect it but i could have sworn it did it to me. Check where u last put the screw on the ECu. I remember when i didnt fully put it counter clockwise, my rpm's were super low and jumpity....well super low from what i remember and could have been jumpity. Maybe u make a mistake and turn the screw clockwise after turning it counterclockwise...just a thought....
Old May 23, 2004 | 06:33 AM
catalinoiu's Avatar
Code 0215 is P1446 "EVAP canister vent control valve closed"
Code 0304 is P0325 "Knock sensor or circuit fault"
I've got these from Haynes manual.
Old May 23, 2004 | 01:43 PM
CKOTuHA's Avatar
Code 0215 is P1446 "EVAP canister vent control valve closed" - What is that supposed to mean?
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
