Hesitation in upper RPMs.
Old May 23, 2004 | 03:15 PM
MAXIN's Avatar
Im getting horrible hesitation in upper rpms. (not sure if this is 'missing' or not)
A few days ago, I had some debre in the MAF that I blew out with a can of compressed air. (cleared the MAF code) But I did drive home that day (about 15-20 blocks) with the MAF unplugged as it wouldnt run with the bad MAF.
After I fixed the MAF problem I got codes 0210 (front bank lean) and 0304 Knock sensor and now this hesitation/(missing?) after 4000 rpms. Cleared codes again, havent got back the 0210 but the 0304 came back again.
Knock sensor resistance is about 5 M ohms. Vacuum seems ok, about 22hg, what would a reading be if there is a vacuum leak? Fuel psi is normal.
Car idles normal, and drives normal under low to medium throttle and in the lower rpms.
Any thing else I should check before replacing the knock sensor?
Thanks.
Old May 24, 2004 | 10:41 AM
Brudaddy's Avatar
Check your coils.
One or more of them might be failing.
I think it is in the "How-To's".
If you need to replace them, get the Mitsibushi ones and not the Hanshin replacements.
Miket2006
Mar 1, 2021 03:55 AM
JonBlz
Oct 5, 2015 06:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
trungg86
Sep 4, 2015 04:58 AM
