95 Maxima stalling problem, intermittent
Old May 25, 2004 | 08:57 AM
meditank's Avatar
Hello to you, newbie here. I have a problem with my California version Maxima, a 1995 manual trans with 250K miles. About once a day, the Maxima will cut out with the clutch in or out, doesn't matter. I have to wait for about one minute, pump the gas once to the floor then turn the key for it to start again. If I don't pump the gas, the engine will just turn and turn without firing up. The car has done this twice in one day the other day, once while driving at 65MPH and the other one was when I was coasting with the clutch in approaching a stop sign. The car has a new fuel filter installed 5 days ago with 2 new O2 sensors---left and front bank but I have not replaced the cat O2 sensor yet. This sounds like it could be a fuel pressure regulator problem or a fuel pump. Others? TIA.
Old May 25, 2004 | 10:47 AM
slag's Avatar
2 things come to mind.
1. Throttle position sensor--when you pump the pedal it gets the sensor out of the flat spot
2. Crank position sensor. When they start to go, they flake out and cause your vehicle to die.
Old May 25, 2004 | 10:50 AM
FLO_BOY's Avatar
3. Bad MAFS wiring...
btw, any codes on the computer?
FLO_BOY
Lakersallday24
Nov 7, 2024 07:31 PM
Samedi
Aug 13, 2015 04:05 PM
Hawkeye61
Aug 12, 2015 06:45 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
yat70458
Aug 3, 2015 01:16 PM
