Need Help Asap
Old May 25, 2004 | 01:49 PM
RedlineVQ's Avatar
Need Help Asap
ok so i was draining my manual tranny fluid and while i was putting the bolt that holds the black thing in place it snapped. So now i have a snapped bolt in the threads and the bolt head broke off clean. Does anyone have any advice for getting it out and getting a new bolt (size).
Thanks,
Robert
Old May 25, 2004 | 02:28 PM
belosic's Avatar
Your most inexpensive option is to use an "EZ-out". Basically, its a hardened drill bit and a tap that bites into the broken bolt to remove it. Look for one at your local harware store, follow the instructions. Just make sure you drill into the bolt perfectly into the center. Use lots of penetrating lubricant (PB Blaster)
belosic
WillMax95's Avatar
to get it out, i think they have a thing at home depot or something that acutally takes out broken screws, i forget whats its called. as for the bolt, i dont know the size but u can prbly get it at autozone or a hardware store.
Old May 25, 2004 | 02:30 PM
belosic's Avatar
oh, and after you get the bolt out, go back to the hardware store to match it.
Old May 25, 2004 | 03:28 PM
1991tsi's Avatar
autozone definitely has bolt/screw extracter kits. they come with an ez-out and left-handed drill bits. get the biggest ones that will fit your application. g'luck...
Old May 25, 2004 | 04:23 PM
sryth's Avatar
That screw is rather tiny, but if you can get a dremel bit small enough, you could make a notch in the top of the screw; then use a flathead screwdriver to back it out.
I assume the bolt is severed flush; anything sticking out?
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
