Sound coming from front driver wheel
Old May 26, 2004 | 02:53 AM
markargente's Avatar
I'm getting a metal dragging sound coming from my front driver side wheel while traveling at speeds around 15-25 mph and is really annoying. You can also hear it while turning in either direction at slow speeds also. At higher speeds, I can't hear anything. When I took off the wheel to check, I didn't see anything hanging there and I rotated the tires. Could the problem be the rotors? Anyone else have this problem? Thanks
Old May 26, 2004 | 03:06 AM
I30tMikeD's Avatar
I bet it's the wheel bearing.
Old May 26, 2004 | 01:32 PM
boo... i just took my car in not too long ago for an alignment and i suspected my wheel bearing might have been going and he said no =/. I really hope its not it. What are the exact symptoms of a bad wheel bearing?
Old May 26, 2004 | 03:07 PM
I30tMikeD's Avatar
That metal on metal type noise that can be heard at lower speeds, I also had a ticking type noise. I let it go so long I had to replace the whole hub and bearings. I did it myself the first time but I must have not gotten the hub pressed correctly because now the noise is back. T
Old May 28, 2004 | 09:59 AM
Cornbread's Avatar
Just brought my car in for the same exact noise and it was only the tire stop. It is a factory installed bolt that, when turned too much, it rubs against the stop (Metal piece). My mechanic put some grease on the bolt and stop and the noise disappeared. I dont know if it is the same problem but it is worth a look. Good luck. Todd
Old May 30, 2004 | 07:33 AM
Hmm.. thanks cornbread. I'll bring it in this week
Old May 30, 2004 | 10:46 AM
njmaxseltd's Avatar
Check your brake pads, the ware indicator might be hitting your rotors telling you it's time for new pads.
It could also be the splash shield in back of the rotor, make sure it's not rubbing against it.
Old May 30, 2004 | 06:06 PM
im positive its not the brake pads, because they were replaced not too long ago. Ill check into the splash shield
kingw323
20
Oct 21, 2015 08:36 AM
AT978
Aug 15, 2015 06:39 PM
follyburr
Aug 7, 2015 09:50 PM
BassAddictJ
Aug 4, 2015 11:38 AM
Jcof88
Aug 3, 2015 10:43 PM
