Rear main oil seal?
Old May 26, 2004 | 03:48 PM
platinum's Avatar
Rear main oil seal?
Whats up guys! I have a question. I have recently purchased a new ACT clutch and a fidanza flywheel. I also bought some redline MT90 for the gear oil. I wanted to know if anyone has done these mods and replaced there oil seal? I was told that it is a good idea and want to do buy but the dealership must order for me. Any experianced comments. Thanks!
P.S.
Thae car has 75000 miles.
Old May 26, 2004 | 04:05 PM
platinum's Avatar
Sorry for spelling errors. Been working overtime and I am tired.
P.S
I HAVE TWO GSR'S UNDER MY BELT AND A MUSTANG.
Old May 26, 2004 | 04:29 PM
Mishmosh's Avatar
If your rear main seal is not leaking, I would be hesitant to replace it. There is a possiblity that you can botch the install and have to drop the tranny again. Moreover, it is a $30 part, even discounted. I have to say though that mine probably started slowly leaking at 80k miles or so--I just didn't realise it...thought it was just high oil consumption in a higher mileage car. Check out the how2 section here or at vqpower.com for instructions. Not hard.
Edit: I guess you want to know if you should order the part now so you will have it come clutch/flywheel install time. Check the bottom hole on the tranny...if there is any motor oil residue, you have a rear main seal leak that should be replaced.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
carlosvq30
Aug 17, 2015 11:32 AM
