What kind of signal does KS send to ECU?
Old May 26, 2004 | 04:30 PM
Kolyan's Avatar
i think knock sensor sends signal in volts (high, low) and then ECU retards timing or not. Is there only 2 signals? and the timing is either retarted or not?
Old May 26, 2004 | 05:27 PM
CKOTuHA's Avatar
I know 0304 points to a problem with the Knock Sensor. Maybe there are other ones.
To check manually u need to use an ohmmeter which is pain in the ***.
Old May 26, 2004 | 08:34 PM
DAVE Sz's Avatar
Hooooooonda.....
How is it a pain? You unplug the connector, touch 2 pins with the leads and you're done. Either way the resistance means absolutely nothing. If you check the ECU and you have a code, get a new KS.
Old May 26, 2004 | 08:40 PM
Kolyan's Avatar
is there a posibility to have a broken KS without ECU giving code? (i know the light doesn't come on for KS) Can the KS be in a working state and maybe worn or something?
Old May 26, 2004 | 08:51 PM
DAVE Sz's Avatar
Hooooooonda.....
If the KS is broken there WILL be a code. It just won't show up unless you check the ECU yourself. Yes.
Old May 27, 2004 | 05:14 AM
Terran's Avatar
The faq explains about an on and off KS and its symptoms.
Old May 27, 2004 | 06:09 AM
Kolyan's Avatar
just what i was looking for ! thank's alot for pointing that out
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
