need help!! my car lags at low RPM
Old May 30, 2004 | 11:08 PM
S15 SR20DET's Avatar
sup guys
i just had this prob goin on like a week ago, i felt it when i was driving in 4th or 5th gear at low rpm then when i try to step on it the car will lag a little then it will start to go my car has 140k on it could it be the transmission or what??
Old May 31, 2004 | 02:55 AM
kidfrostbite's Avatar
Originally Posted by S15 SR20DET
sup guys
Ignition coils? Are you feeling a "miss" at low rpms, or just lag?
Old May 31, 2004 | 04:14 AM
I30tMikeD's Avatar
sup guys
How low of an rpm are you talking about?
Old May 31, 2004 | 05:37 AM
njmaxseltd's Avatar
Put your stock intake back in place.
Old May 31, 2004 | 12:23 PM
around 2,700 RPM
the car like keeps on cutin off but not for a long time like a second or so then it will start to go
Old Jun 5, 2004 | 01:57 PM
Radiohead's Avatar
Check for knock sensor code
Old Jun 5, 2004 | 02:15 PM
i got a new knock sensor like 2000 mile a go
Old Jun 5, 2004 | 08:11 PM
Magikone69's Avatar
MAFS, check 2 see if you have this code. i was having this same problem and got the code for MAFS. i took it off and there was a thin film of grease and dirt, i cleaned it off an and it was ok from there on. MAFS= mass air flow sensor, in-case you didnt know. good luck
Old Jun 5, 2004 | 08:32 PM
ThunderMaxi's Avatar
I was am having the same problem but the CEL doesn't come on... Where is the MAFS? what does it look like? Help. Thanks!
Old Jun 5, 2004 | 11:11 PM
how do u clean the MAF??? how do u check for codes
Old Jun 5, 2004 | 11:54 PM
Radiohead's Avatar
To check for ecu codes:
http://vbxmaxima.8m.com/ecu.html
The MAF is located in teh throttle body.
Here's how it looks:
http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/MAFSensorMod.htm
Old Jun 6, 2004 | 06:42 AM
Magikone69's Avatar
i just cleaned the screen with a semi damp cloth and got all of the gunk off, i didnt touch that lil sensor inside.
Old Jun 6, 2004 | 09:47 PM
Radiohead's Avatar
I just came across these threads, might be bad coils
http://forums.maxima.org/showthread.php?t=316100
http://forums.maxima.org/showthread.php?t=315658
Old Jun 7, 2004 | 11:39 AM
bigherm033's Avatar
Originally Posted by Radiohead
Somthin similar happend to me about 6 months ago. If it shuts off at low RPMS's and it feel like your car can breath then it might be your catalytic converter is clogged. this happened to mine at about 126,000 miles and i just replaced my y pipe with a performmance one and my cat with a test pipe. Although if you have to worry about emissions get a hi-flo cat.
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
MaxStock
Aug 12, 2015 08:33 AM
