Coolant Temp pins?
Old May 31, 2004 | 07:26 PM
LIMaxin
Coolant Temp pins?
Does anyone know which pins on the ecu i have to tap into in order to wire up a coolant temp gauge?
Old Jun 1, 2004 | 08:12 AM
LIMaxin
Bump... anyone know?
Old Jun 1, 2004 | 10:50 AM
96maxdaddy's Avatar
you can probably just use the wire coming off the coolant temperature sender, its he same wire that is used by the ecu for the stock gauge. As far as were it is on the ecu I dont know. Let me know how you do cause I am curious as well.
Old Jun 1, 2004 | 11:38 AM
LIMaxin
Is there any sort of other temperature sensor i can tap off of in order to use this gauge w/o extra hardware?
Old Jun 1, 2004 | 12:19 PM
96maxdaddy's Avatar
the only other sensor in the cooloing sysytem is the engine coolant temp sensor. It does the same thing as the sender, but the ecu uses this info to help calculate the air fuel ratio. I dont see why you couldnt use either or, but I think it would be easier and also cheaper, if you have problems, to use the sender.
Old Jun 1, 2004 | 12:43 PM
LIMaxin
and the engine coolant temp is different than the temp displayed on the dash?
Old Jun 2, 2004 | 10:13 AM
LIMaxin
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
captchaos
Mar 15, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
