ECU Code 0101 (Camshaft position sensor) on '96 i30
Old Jun 1, 2004 | 06:57 AM
humberto_i30's Avatar
My brother's car (Infiniti i30) is dying suddenly and we pulled the codes out from the ECU, diagnostic code is 0101 (Camshaft position sensor), where is this sensor located at ? Where can I buy it ? and what's the cost for the sensor ? any advice ? comments ? Thanks a lot !
Old Jun 1, 2004 | 11:23 AM
Kevlo911's Avatar
Kevlo for President
0101
My book says DTC 0101 is caused by the Camshaft Position Sensor (Phase). This sensor is located on the engine front cover facing the camshaft sprocket. It detects the cylinder number signal. The Engine Control Module uses this signal to control spark plug firing order and also to sequence the fuel injectors correctly. If the CPS is bad the ECM will fire the plugs at the wrong time, or not fire them at all. This would account for a no-fire symptom.
mvm062
Nov 30, 2020 09:00 AM
