Is it possible to add stock headlights that didn't come on a max?
Old Jun 1, 2004 | 01:04 PM
athlon omega's Avatar
I was going to switch to a 97 bumper with 97 fogs but my 95 max didn't come with fog lights. Is it possible to install 97 foglights with the new bumper and will they function properly? I didn't see it addressed in the How To section. Or should I just go with angel eye foglights? If so, which are the best ones to go with? Thanks.
Old Jun 1, 2004 | 01:09 PM
Nismo's Avatar
you will need the mounting bracket and also a turn signal stalk that has the foglight option on it unless you do your own wiring to a separate switch or something.
Old Jun 1, 2004 | 01:12 PM
oTranscendental's Avatar
If you want the stock look your gonna have to cut your bummper, plus all the stuff nismo said. And you will have to get the relay and fuse for it.
If you get an aftermarket set, you can choose size shape color and brightness. Pluss the install might be a little easier.
Your call homie.
Old Jun 1, 2004 | 06:48 PM
Thanks guys. I might just go with aftermarket. That's sounds a lot easier.
Old Jun 2, 2004 | 10:40 AM
Brudaddy's Avatar
The aftermarket would possibly be cheaper too.
I mean, I love the way the stock fogs look, but Nissan is way too proud of them. I just had one of mine crack from a rock, and I am hoping it is not deep enough to really matter and make the bulb not work. They are just really expensive to replace.
Old Mar 12, 2005 | 07:46 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
is it easy to swap the stalk to one that has the foglight controls on it as i have the factory fogs, the relay but the stalk in my car doesnt have the foglight option on it.
incubusjohnny
Nov 3, 2015 05:18 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
jholley
Aug 11, 2015 09:38 AM
dauntlessmax
Aug 5, 2015 10:29 AM
