Water Temperature and Oil Pressure Guage Readings? What should they be?
Old Jun 2, 2004 | 10:10 AM
95CustomMaxima's Avatar
Like the topic says, what are you guys reading for Water Temperature and Oil Pressure? I read about 20-25 psi at idle for Oil Pressure and about 50 psi when driving steady and about 80+ at WOT. As for Water Temp Im at about 130-160 after thermostat opens. Let me know how Im doing.
Thanks,
-Nick
Old Jun 2, 2004 | 10:38 AM
Chunger's Avatar
My other car is a Hybrid
Oil pressure sounds right...
82C with AC on, 92C max on my water temp...
Old Jun 2, 2004 | 10:42 AM
maxspeed96CT's Avatar
The original VQ...
what did you hook up water temp to, i hooked it up to the gauges inthe backand i got a reading of 230, i knew it was off but used it as a guide, you sounds like its reading to cold.
Old Jun 2, 2004 | 10:49 AM
Broaner's Avatar
2060lbs and falling...
I don't know about Oil pressure. I assume you have an aftermarket gauge for that. As for temp gauge I regularly read 178-190 depending on conditions. On a 1.5hr drive on Sunday I leveled out at 183 the whole way. I have a brand new radiator and of course new coolant. My old one was kinda blocked up in the front and the coolant was old but I guess the thermostat would compensate.
Old Jun 2, 2004 | 11:19 AM
1MAX2NV's Avatar
You water temp sender needs better grounding. The reading is off. The themostate opens at 180F. Oil pressure depends on your engine's RPM. I believe at idle after it's warmed up should be around 10psi or 15psi. I need to double check that with my FSM.
Old Jun 2, 2004 | 03:24 PM
Broaner's Avatar
How do you guys know oil pressure? My Auterra sure as hel! doesn't do it. I'm kinda p!ssed actually. So, you saying I need to add another groundwire to the thermostat. Which wire is the ground. I can check and see if its corroded or chaffed or anything.
Old Jun 4, 2004 | 10:07 AM
bump...Should I reground the water temp gauge ground? Or am I suppose to ground the temperature sensor itself? because right now I only have a signal wire hooked up the temp sensor.
Thanks,
-Nick
Old Jun 6, 2004 | 03:54 PM
Broaner's Avatar
I'm interested in this also. Where exactly is the temp gauge? I'm skeptical that mine could be off that much because I was running 189 last night. Is the thermostat different from the temp sensor? Details? Please.
Old Jun 6, 2004 | 08:22 PM
1MAX2NV's Avatar
First of all...everyone that has aftermarket water temp gauge ie. Autometer, greddy..should be using the sender that came with the gauge. The sender should be screwed into a metal part. If it's not, you need to ground the body of the sender to a metal part via wire. You can spot weld the wire or use JB weld.
Old Jun 7, 2004 | 06:50 AM
Broaner's Avatar
Yeah, but I'm using an Auterra and it was 189 again today.
Actually here is an instance that I was running 196. In a parking lot it will sometimes rise to 200+. WTF?
Old Jun 7, 2004 | 07:40 AM
Stephen Max's Avatar
That is not unusual. A hot engine idling at standstill relies solely on the cooling fans to reject heat. On a hot day it's going to result in a higher coolant temperature than while moving. Back in the day before cooling systems became as efficient as they are now, it was not uncommon to have to turn the heater on full blast on hot days to keep the engine from overheating when sitting still or moving slowly in traffic jams. Even now I hate to use the AC on really hot days out of sympathy for the engine. My kids think I'm nuts.
Old Jun 7, 2004 | 07:42 AM
1MAX2NV's Avatar
Does the Auterra tap into the ECU to get those readings? similar to Techtom?
Old Jun 7, 2004 | 07:46 AM
1MAX2NV's Avatar
I find turning on the AC helps the cooling system at standstill because that extra fan spinning on the AC condensor also cools off the radiator.
Old Jun 7, 2004 | 01:24 PM
Broaner's Avatar
Whoa, are your serious? One fan is for the radiator and one is for the condensor or did I misunderstand? Whats going on?
lowpost99
Oct 26, 2025 06:53 PM
boomerbrian
Oct 31, 2018 10:25 AM
kjlouis
Oct 3, 2015 05:29 AM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
