***engine bore technical question***
Old Jun 3, 2004 | 06:15 PM
maximus_pr's Avatar
if one increase the bore of engine from 93 to 94mm using the HP kit with a comp. ratio of 10.5:1 that will give how much estimated hp also how much displacement is increased
HP kit
Old Jun 3, 2004 | 07:42 PM
BEJAY1's Avatar
Conecarver
Good question. Anybody? Buehler. Buehler.
Old Jun 3, 2004 | 08:23 PM
Linkage23's Avatar
a bore increase that minimal will not yeild too much hp but will allow you to have higher gains when modding....i believe it would only raise your stock hp at most 7-10, not for sure but I have bored other engines and not too much hp was gained.....you should jsut do it and let everyone elese gain from your decision.....good luck though
Old Jun 3, 2004 | 10:13 PM
maximus_pr's Avatar
i know the bore alone won't yield lot of hps but increasing the comp ratio as well
i was thinking maybe 25 hp
Old Jun 5, 2004 | 02:05 PM
maximus_pr's Avatar
anyone else?????
Old Jun 5, 2004 | 03:37 PM
nismology's Avatar
The bore is large enough. Our engines are relatively stroke impaired so you would be better off with a stroker crank, possibly VQ35??
Old Jun 5, 2004 | 05:14 PM
maximus_pr's Avatar
so its posible to use the crankshaft froma 3.5 or not from what i read on that thread it never been proved or i'm wrong?
Old Jun 6, 2004 | 12:02 PM
bruteMax's Avatar
1234567890
Miket2006
Mar 1, 2021 03:55 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
drworsley
Aug 20, 2015 05:07 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
