So i went to chage the oil in the mt...
Old Jun 5, 2004 | 05:25 AM
thekenone's Avatar
and i could get the filler hole open. so i sprayed so pb blaster and what the he ll the threads have some kinda putty around them. i think it still ne to be changed but does that mean someone stripped the holes and had a leak. is this why the car was soo cheap. i only used a ratchet i think i could get it off w/breaker bar but not sure which way to turn it. towards ground or engine. what should i do?? any suggestions plz.
Old Jun 5, 2004 | 06:21 AM
SkinnyMax's Avatar
maxima no more
turn it counter-clockwise to take the plug out, not sure what the putty stuff is, might be just some dried up grease or some teflon sealant.
Old Jun 5, 2004 | 09:02 AM
96maxdaddy's Avatar
That stuff is more than likely sealer. The dealership coated my plug with it when they rebuilt my trans.
I just used a 1/2 inche breaker bar, and I put the end into the plug without a socket on it, just the bare end.
as far as the direction to turn it just remember this little grade school saying
Righty tighty, lefty loosey.
Old Jun 5, 2004 | 01:26 PM
thekenone's Avatar
well should i buy something to put back on the threads to reseal it??
Old Jun 5, 2004 | 01:51 PM
SkinnyMax's Avatar
maxima no more
you can throw some sealant on if you want, won't be any trouble, but I have never had to put any on my plug when I change tranny oil. just torque it to spec and it should be good to go.
Old Jun 5, 2004 | 08:30 PM
thekenone's Avatar
ok one last question where should i get the oil all of it around me says gl5 gl4 gl3 on the same bottle. should i use this or not.
Old Jun 5, 2004 | 09:02 PM
96maxdaddy's Avatar
NO!!!! If you care about your car, and shift quality dont use that crap. Also dont use GL-5, even though some aotu parts stores will tell you its better . What you need is a straight GL-4. You might have a hard time finding it so I suggest using Redlines MT-90, which is a synthetic GL-4.
Old Jun 5, 2004 | 09:23 PM
kingrukus's Avatar
no more maxima...
Im using amsoil series 2000 that says GL2 through GL5 and it drives decent.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
