Just installed Xtravision bulbs, but the beam is lower than stock?....
Old Jun 6, 2004 | 09:45 PM
NachoNYC's Avatar
Do I have to reaim my headlight?...I installed an extravision bulb into the passenger side, and the beam projects lower than stock. The beam is noticeable brighter, but it's lower, so I was thinking about returning it. How can I fix this?..
Old Jun 7, 2004 | 05:26 AM
95Max's Avatar
I put the ExtraVision in my 95 and my girlfriends 99 Accord and did not have this issue. I would check to make sure its in correctly
Old Jun 7, 2004 | 05:48 AM
JPMax's Avatar
What's next!?..
Yes, I'd make sure it's in correctly first. If it is, then you can adjust the vertical aim to correct it.
I forget which screw it is..
Just park the car in front of a garage door or wall about 10 feet away and turn on the lights. Then adjust to match the other one.
Old Jun 7, 2004 | 06:52 AM
95Max's Avatar
get an ExtraVision for the driver side.....you will like the light. You may not have to adj...remember that the ExtraVision is not only 20% brighter but has a better light pattern....ie puts light on the road where you want it. get an ExtraVision for the driver side and see how it works (but check the pass side install).....you will like the light....with both bulbs the same.
Old Jun 7, 2004 | 09:48 PM
NachoNYC's Avatar
I now have xtravisions in both of my headlamps. The passenger side beam is still lower than the driver sides. Which screw do i have to get to to raise the beam?....and which way should i turn it?...
thanks
tcb_02_max
Sep 11, 2015 12:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 10, 2015 11:21 AM
