How bad is it?
Old Mar 28, 2001 | 03:28 PM
tecuhtli's Avatar
Ok guys and girls, I need your help. I recently had my dealer do a full inspection done on my 96SE, one thing they found was Oil Pressure Switch Leak , how bad is it, should I worry and can I do this. The dealer wanted $91 to replace it, a bit high like any dealer. Any help will sure be appreciated, Thanks in advance.
Old Mar 28, 2001 | 03:40 PM
Daniel B. Martin's Avatar
Do-It-Yourself
This job can be done by the home mechanic. Raise the front of the vehicle and support it on sturdy jackstands. Slide under. The OPS is easy to see and reach. It is "just around the corner" from the oil filter, in the rear face of the block. Peel back the protective rubber boot. Press and wiggle to disconnect the electrical connector from the OPS. Use a special OPS socket or an ordinary 1-inch deep socket to unscrew the OPS. A few ounces of engine oil will dribble out, not much of a problem. You can do the whole job in half an hour, including clean-up time.
Old Mar 28, 2001 | 03:44 PM
Jeff92se's Avatar
I'm needing a caw
Re: Do-It-Yourself
You mean replace it? Or just put more sealant on it? I always wondered if it leaks from the threads or from the swtich/sensor itself?
Old Mar 28, 2001 | 03:47 PM
AntGVR4's Avatar
Not a problem
I changed mine a month or two ago ...
the piece costs $5 dollars i think .. ? or maybe it was $13
either way don't pay the mechanics at nissan to do it. Daniel B. Martin described how to change it perfectly, do it your self.
Ant
Old Mar 28, 2001 | 04:40 PM
DFWmax's Avatar
if its the thingy thats connected to the cable that runs right under the oil filter, you can probably get to it without jacking up the car. just turn your steering wheel all the way to the right.... then take the plastic panel off of inside the right front wheel well... you'll see the oil filter and it should be to the left of it.
Old Mar 28, 2001 | 04:47 PM
Re: Re: Do-It-Yourself
It could be either. Before removing the Oil Pressure Sender you could gently tighten it. If it is noticeably loose, just screw it in tighter. I'll bet it is tight enough. The crimp seal between the metal shell and plastic head can loosen up, and the right "fix" is replacement.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
