where can I find coil packs for cheap????
hello orgers I would like too know where I can find coil packs for cheap I went too auto zone and had trhem check for ghost codes (my cel wasnt on) and they told me I have 2 codes k.s. code and misfire on cyl.#5 so I know that the car has been sluggish lately and especially under load or going up hills and in low rpm you can feel it start too slightly missfire so I know from everything I've been reading on the org.lately thats most likely the prob any help would be appreciated... also should I consider coil packs from a junk yard if they look good? also will any year i.e 95,96,97 interchange with me? I'm a 98 thanks
sx7r is selling his used coil packs...
http://forums.maxima.org/showthread.php?t=316068
$50/coil + shipping...obo
jerryromenissan.com us promo code "maxima" to get 12% off it comes to about 55-60 dollars. each. if you need some injectors, most likely if your coil isnt to blame, i can sell you some used injectors for pretty cheap.
Those words "cheap" and "coil packs" don't really go together.
Both of the suggestions are about as good as you are probably going to get.
Make sure you don't get the Hanshin ones, as they are the bad brand that are in there.
Get the Mitsubishi brand, and you should be set.
I would just replace them one at a time and start with #1, then #3, and then #5. No need to replace them all if they all don't need it. That will run you over $300.
