Help me find where to buy last pieace for my MEVI!!
Old Jun 8, 2004 | 10:16 AM
mighteatyou's Avatar
I have in boxes
-MEVI
-Vaccume canister with built in checkvalve
-vaccume hoses
-Summit Racing RPM switch(with Reset instructions)
-Relay switch 30amp
Now i only need to find out where to buy the CORRECT SOLENOID!
i ordered one online but i dont think i got the correct one it is GM part # 1997152.
i dunno if this is right since its a GM part for my imported maxima.... im not sure what to do so if anyone could just lead me to the right place too buy the GM solenoid i would greatly appriciate it. Somone told me there is a daws dual solenoid, but thier websites does not have it. The bible doesnt help me much with the MEVI. So i need somone who has thier MEVI up and running possibly an exact website or anywhere i can order this part. Please someone pull thru for me im really struggling
Old Jun 8, 2004 | 02:12 PM
Stephen Max's Avatar
Every Nissan in every junkyard has a vacuum solenoid. I think Sentras have about five of them. They're pretty much all the same and shouldn't cost you more than about $10.
Old Jun 8, 2004 | 04:39 PM
deezo's Avatar
The GM solenoid will work. There are plenty of us with them.
Old Jun 8, 2004 | 09:16 PM
volkl77's Avatar
Out of the box the GM solenoid will work. deezo can corrrect me if I'm wrong, I'll know better after I install mine this weekend. The chromed port is open to air, the one that you can blow through connects to the MEVI actuator and the final port to your vacuum canister.
deezo... how did you connect to the Gm solenoid electrical contacts? I've tried finding the correct GM pigtail harness but no luck
Old Jun 9, 2004 | 07:09 AM
okay thanks guys, so the gm solenoid that i have now will definatly work i can bring it too the mechanic and have no problems? Im not going to put this on myself im going to let someone else do it for me. I just wanna make sure i have everything i need prior to going in because i dont want any car downtime i have a job i have to be at every day
Old Jun 9, 2004 | 05:05 PM
volkl77's Avatar
Ok...got it worked out today...
If you are using the GM ported vacuum solenoid part# 1997152, you can use the pigtail with part# 1210-1857.
You will need to cut a slot down the center between the contacts to properly fit the solenoid. Easier done than said ..just use a sharp utility knife.
Cheers!
Old Jun 9, 2004 | 05:07 PM
volkl77's Avatar
p.s.
The dang pigtail is worth more than the solenoid! About $22! At least it will be a clean install
Old Jun 9, 2004 | 06:18 PM
okay now im confused
p.s.
Old Jun 9, 2004 | 06:42 PM
volkl77's Avatar
confused about?
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Sep 10, 2015 06:33 PM
mikebla
Sep 3, 2015 05:37 PM
crazyespn
Sep 3, 2015 01:30 PM
