Gettin RPM Signal for MEVI ???
Old Jun 11, 2004 | 01:15 PM
matty's Avatar
Im having a problem with my car and hesitation under light load..gas on gas off, gas on...bog bog bog and it goes
explained here http://forums.maxima.org/showthread.php?t=316304
I put in my MEVI about a year ago and Im tryin to pinpoint when this problem is generated from and I thauhgt about it and I tapped for the RPM signal at my 6th Coil top left hand side of the engine....
I remember when I tapped for the RPM switch one night I took apart the wire at the RPM switch and the car ran like pure c*ap..hesiting bad
Im trying to think maybe by tapping there it made the signal alittle bit less going to the coil and its messing up the car somehow ??
Does everyone ususally tap inside by the ECU or at one of the Coils ??
-matt
Old Jun 11, 2004 | 01:16 PM
Y2KSESteve's Avatar
Mine had to be done at the ECU. It wouldn't activate at the coils..
Old Jun 11, 2004 | 01:20 PM
matty's Avatar
Mine has been activating at the coils, but Im tryin to figure out, maybe this is where im gettin that slight hesitation from
-matt
Old Jun 11, 2004 | 03:04 PM
matty's Avatar
How do you tap under the dash ?? any writeup ??
-matt
Old Jun 11, 2004 | 08:39 PM
matty's Avatar
bump to the top
Old Jun 12, 2004 | 07:52 AM
matty's Avatar
bump to the top
Old Jun 12, 2004 | 08:13 AM
Y2KSESteve's Avatar
I don't have a write-up on this. I could probably get in there and take a picture of it, but it might take me a few days...
Old Jun 12, 2004 | 08:42 AM
Spaniard's Avatar
Y2KSESteve,
was it as straightforward as cutting the wire and splicing a wire out, reconnecting with electrical tape? And it was the green and white wire, if memory serves from another post. Can you please confirm... thanks in advance
-E
Old Jun 12, 2004 | 08:44 AM
matty's Avatar
I thaught it was a flat green wire coming off the ECU and I thaught you needed to solder all your connections down there ??
any write ups are greatly appreciated...I know there are some
-matt
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
