Dyno with TS ECU and MEVI....
I dynoed my car today with a zip tied MEVI, and a TS ECU...
http://1fstmax.maximaclubca.com/dyno
First base run is with MEVI(not opening)
Second run MEVI and ECU (mevi not opening)
third run MEVI zip tied open, and ECU
193.6 HP and 179.4
Mods:
Stillen hybrid intake
Cattman Y
Greddy sp catback
MEVI
GForce ECU
Special thanks to my sponsor Top Element Tuning, and Larrio.
193.6 HP and 179.4
Mods:
Cattman Y
Greddy sp catback
MEVI
GForce ECU
Originally Posted by Guttermouf5150
hey 1fstmax, how do i go about joining your guys' club or just hanging out sometime? i went to the website, and there's not much i can do there.
![](https://maxima.org/forums/images/smilies/support.gif)
Originally Posted by Big D
Is it just me or does it look like his TQ is low by about 20? Is this because the MEVI is open the whole time or because it's a GEFORCE ECU? Still nice number man.
Because the mevi is stuck open.
Originally Posted by 1FSTMAX
Well the RPM switch is working, because the MEVI does try to open. But for some reason it seems that there is not enough vaccum to open the VI.
Originally Posted by I30tMikeD
I had the same problem at one point and it was my vacuume canister. Don't know what type canister your using but the napa one I use has an internal check valve that went bad.
I have the Napa too but just to be safe, I used another check valve. Also make sure the MEVI lever arm can be opened/closed freely--some people had a slightly bent butterfly rod that made activation difficult.
I must say even with the VI zipped open, and GForce ECU the car pull harder than ever. I really wansn't expecting these numbers. I'm happy. Also what other mods can I do, to break 200WHP? I was thinking get the VI working properly, adding a lightend flywheel, some grounding, V-AFC. I don't want a UPD. Anything else besides cams?
Originally Posted by jdmmax
i have one harlan and it works fine for me to.
alfonso im right down the street from your work. why don't you come by and buy a nissan vaccum canister with a check valve.
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
Originally Posted by Larrio
i've plotted 1fstmax's dyno views in runviewer, its scary how much the 4th gen with MEVI + ECU can make after 5k rpm.
but i can still smoke him...
haha...
![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
![BowDown](https://maxima.org/forums/images/smilies/bowdown.gif)
my car is old man....
![Slap](https://maxima.org/forums/images/smilies/slap.gif)
Those plots are terribly confusing to read. Your torque numbers seem a bit low, but like I've always said dynos are just tuning tools and they aren't to be used for just "numbers" bragging. It looks like the TS ECU provides you with a good midrange increase exactly like the JWT ECU does. Many people are seeing 190+wtq from 2800-5000rpms with the MEVI/JWT ECU. I haven't dynoed my MEVI/JWT ECU combo, but with just my MEVI and y/i/UDP I saw 189whp/185wtq.
I know that your MEVI isn't operating correctly and you have to ziptie the unit open, but it's safe to assume that you can use the below 5300rpms plot of run #2 and the 5300+rpms of run #3 and that will pretty much show the capability of your car. I'd say ~195whp/180wtq is a safe bet. The only thing that sucks is you're still being held back by the rev limiter and that really kills the 0-90mph performance capabilities of this setup. The ECU will help you in the 1/4 mile, but that extra rpm you get from a 7000-7200rpms will place you deep in the powerband once into 2nd gear. Hopefully TS will crack the code.
