Those who have reverse indiglo gauges, did your transformer hum?
Old Jun 13, 2004 | 05:08 AM
pocketrocket's Avatar
I just got my reverse indiglo gauges from procarparts last week. The transformer hums, high frequency when I have blue selected. I don't think it's normal.
The dimmer switch has a toggle with 2 settings: blue / green. It has a rotary dial for illumination intensity.
I first tested it directly to a spare battery in my basement, and that thing hummed pretty loud when I had it on blue. At green, there is no hum.
Called up procarparts, they said it''s because it's grounded so close to the battery (huh?????????), so they advised to tie it to the actual illumincation circuit in the cabin. Ahh, tried the cig lighter, close enough. Still humming in blue only.
Also a sidenote, anyone running 4-LED bulbs in their cluster? If so, how well do they illuminate the needles? I don't care about the hotspots since the reverse indiglo gauges will lay on top of them anyway.
Old Jun 13, 2004 | 07:43 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you actually got regular indiglo gauges. reverse only has one setting. i have both and the reverse is much better.
it does hum loud in blue, but the only solution to fix this would be to get a ground loop.
Old Jun 13, 2004 | 10:10 AM
Nismotic's Avatar
Always sunny in philly
yup, one of the reasons why i went back to OEM
Old Jun 13, 2004 | 06:36 PM
killcrap, I got reverse indiglo gauges, I can't stand the indiglo backlight of the normal gauges. Kinda cheesy for my taste.
These are the ones:
The dimmer switch has a setting for blue and green (though the green isn't quite green, more like pale blue). The blue setting is truely blue, matches my window switches and everything else really well.
Can't stand the hum when it's on blue setting
What shall I do?
Sidenote, will 4-LED bulbs light the needles up better? I don't care about hot spots, since the reverse indiglo gauges will sit over the regular ones.
Old Jun 13, 2004 | 06:39 PM
Y2KSESteve's Avatar
My reverse gauges hum and if it ever bugs me, I just up the volume a few notches.
Old Jun 13, 2004 | 07:01 PM
NYC_Maxima97's Avatar
Mine doesn't hum in blue nor green, maybe it's not the same make. not sure
Old Jun 13, 2004 | 08:47 PM
NYC_Maxima97, what kind do you have?
Y2KSESteve, I'd do that except that I'm rather sensitive to high frequency electronic buzz. Most don't hear it or barely do, but in the case of the reverse indiglose for example, I can hear the hum from across the room
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
Bonka
Sep 14, 2015 11:18 PM
