Maxima failed emissions test. Y Pipe??
Took my car for inspection today and it failed emissions. Here are the readings
HC was .78 it should be up to .60
CO was 5.14 limit was 10 so this was ok.
NOx was 2.20 limit was up to 1.50
they ran twice, both times it failed. The guy was nice enough to hook me up (he had a supped up Jetta VR6), he said he's prob wouldn't pass either. Anyway to make the long story short, can this be cause of the Y pipe and the elimination of the pre cats or can it be something else? Any thoughts? I'd really appreciate it.
thx
Eugene
thx
Eugene
i guess NY emissions are different than GA ones... OBDII cars down here don't get the probe up the tail pipe to check readings, we just get something plugged into the ECU to check to make sure everything's working properly....
how long had the car been running prior to going to the emissions place? I've heard that after getting a y pipe the cars need to be warmed up for a while so the cat starts working... just my .02
Drive your car for like 30 minutes right before the test and don't turn it off when you get there. You can try using some SeaFoam to get some carbon out and stuff http://www.aquatune.com/reports.html http://www.protecusa.com/tb_puragas.htm
http://forums.vwvortex.com/zerothrea...ostid=12409106 Could be the O2s or cat
You can find more info on google or something. Search for "failed emission hc nox" or something like that
We have strict emisions here too. Pipe in the exhaust test etc. It's pretty safe to assume if you are failing and you have 120K your Cat is done. Yet you only have 81K, is this mostly city driving if it is could be time to replace it. I had one vehicle and at 120k the Cat actually blew up! Put a new one in and it flew through emissions reading better than it had for the previous three years. A 7 year old Cat is pretty old regardless of mileage, I'm sure you'll pass no probs with a new Cat, I'm sure your Y-pipe isn't the cause.
Greenmaxspeed
Aug 31, 2015 09:06 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
yat70458
Aug 3, 2015 01:16 PM
