pics of clear taillights?
I bought mine but I'm going to do my stock pairs. From what I've seen, they look OEM
Check this page out.
http://www.brianv.net/mods/taillights/
I got the red/clears from redlinemax.com, but I didn't like that the tails didn't match the trunck light that good, so I had to open them, and move the insterts to my OEM tails.
They were $99 bucks
They were $99 bucks
i did a really sh1tty job on mine... if you look close you can see all sorts of mistakes. i wish i did a better job, but i really dont wanna reopen the lights again. i already got a little crack on the outer right, and ripped the corner off the left inner. i superglued it back *sigh* my max is so ghetto. i might try and pick up a some new headlights from a junkyard, and do it again.
i just cleared my taillights, and i used the oven method to heat them up. it was super easy! i don't know how hard it is with a heat gun, but i doubt it would have been that easy.
just in case anybody was thinking about doing it.
probably the hardest part of the whole thing was cutting out the insert from the light cover. i used a paper template. even that only took one try plus a little fine tuning.
btw, i used a dremel tool. i tried with scissors first, and it is pretty much impossible. the cover just breaks.
so do you guys leave the 194 bulb on the outside, even if you take out the red cover? i can see that bijan gxe does.
Originally Posted by ohannon7
what Dremel attatchment do you use? The first time I tried it I melted the plastic b/c it got too hot, I was using the flat grinding wheel i think
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
