POS Momo shift knob Help
POS Momo shift **** Help
Guys i spent 80 bux on this momo shift ****. THis **** is falling apart. Whe i shift hard the **** comes lose and i gotta take an allen wrench and screw it down. And the momo sticker comes off.. WTF! Should i send it back and have them give me a new one?? I bought it off of ebay. But momo should stand behind there products...
I have a Momo shift **** (with set screws holding it in) and it has never come loose once. I tend to wonder about the authenticity of it if it came from ebay...mine has been nothing but a joy to own.
NOTE- Put down towels around the console/shifter area to prevent shavings from making a mess. Hope this helps.
Originally Posted by amb4081
I do not doubt the authenticity of it. I had the same problem with my MOMO when mated with a STS. It kept sliding off the shifter. What I did was remove the set screws and position the **** where you want it to stay. Next mark where the holes are with a marker/pencil. Remove the **** and you will have three marks on the shifter. Get a drill bit as close to the set screw size but a little bigger. Drill deep enough into the shifter so that the set screws will be seated in the shifter which will give them something to grab when you're going thru the gears. Mine has not come off since performing this on the shifter.
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
atriuum
09-28-2015 01:19 PM
