WTF Happen'd!?
Old Jun 15, 2004 | 10:51 AM
Maxamillione
WTF Happen'd!?
I'm trying to figure out what happen'd to my Max the other day.
About a month and a half ago I bought a 97 Maxima SE. Runs w/o any problems and I really love the car. But just the other night as I was driving home from the club my speakers cut out. The radio still had power but there was no sound from the speakers. Then a few minutes later the ABS Light came on. I kept driving since I wasn't far from home but a few minutes later, the check engine light came on, and all the other lights on the dash came on one by one. Suddenly the car lost all it's power and I had to get to the side of the road.
Well I tried to turn it over but it wouldn't, it had nothing. No headlights, no brakelights, nothing. So, I went home and got my jump pack (should have kept it in the car) and jump that summ-b!tch. Well, the car started just fine and kept my foot on the gas to keep it reved. Then, it died again after about five minutes. So I gave it one more try w/ the jump pack and it started up fine and I made it home w/o it cutting off.
Now, I'm no car expert like most poeple here but I've been trying to learn more about them over the past few months. I've spoke to a lot of people and I keep getting the same response about what the problem might be, and that's the "Alternator". The car will turn over but very slowly. It has to build up in order for the car to fully start. I have it at the shop right not getting a Diagnostics Test but I was wondering if anyone else has had this problem? Also, the car sounds a lot lounder when it is running and as I depress the gas pedal the noise gets lounder. Kind of a "Whhhrrrrr". Nothing really strange sounding, just not right though.
Any advise or feedback would be cool. I love my max and I don't want to hurt her!
Old Jun 15, 2004 | 11:54 AM
MAXRB8's Avatar
Sure sounds like your alternator, let us know after they check it out, it could be just the belt but doubt it
Old Jun 15, 2004 | 12:16 PM
JPMax's Avatar
What's next!?..
Most likely dead battery due to alternator death.
Old Jun 15, 2004 | 12:24 PM
95stillenmax's Avatar
Old Jun 15, 2004 | 12:28 PM
mteller's Avatar
Put me down as another vote in the alternator column.
Old Jun 15, 2004 | 12:51 PM
95bkackmax18s's Avatar
believe it or not the same exact thing happened to me last weekend. i thought it was the alternator too, but i bought a new battery and tested the alt. and the meter showed the alt. was doing just fine-14 volts i think-( by the way i have a 95 and i still had the original battery) good luck
my gf has a 93 max and she had a simillar problem and it turned out to be a lose wire.
Old Jun 15, 2004 | 12:56 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
sure way of knowing when ur alternator is going out is,
1) your parking brake light is on (cut's off daytime running lamps is equiped to conserve whatever of the battery is left)
2) your battery light is on
3) abs light goes one (if equipped, turns it off also to save battery.)
Old Jun 15, 2004 | 02:59 PM
macallik's Avatar
same thing happened to me, it was definately the alternator
Old Jun 15, 2004 | 09:28 PM
bennny
so if my parking brake light is always on since i got it back from one of the shops it means my alternator is going out? My max has 116k and the parking light started at 114, sometimes it goes off but mostly stays on now...what other symptoms can i look at to check it out ?!
Old Jun 15, 2004 | 09:59 PM
OneToughMax's Avatar
WHAT???
Old Jun 15, 2004 | 11:18 PM
toofast240's Avatar
Alternator, dead battery, lose wire... All good possibilities!
Old Jun 16, 2004 | 06:22 AM
NmexMAX's Avatar
dot dot dot ...
Check ground wires if lights dim very noticeably when you press the brake. Check all battery wires, GND and (+), check alt if Battery light comes on.
No 4th gen came with DRL's (daytime running lamps), so that is DEFINATELY out of the question.
Old Jun 16, 2004 | 06:26 AM
Slaytan69's Avatar
check your fuse as well....my old camry died on me one time and we caused a lot of damage before we found out it was just the fuse
Old Jun 16, 2004 | 07:39 AM
Maxamillione
Ahh!
It's the Alternator...I'm gonna replace it tonight. Funny thing was, when I went to pick it up from the shop, it fired up just fine. Well, I'm still gonna replace the d@mn thing. Better safe than sorry, you know.
Old Jun 16, 2004 | 12:12 PM
MAXRB8's Avatar
Sorry dude but ALL 4th gen's come with DRL's in Canada
Old Jun 16, 2004 | 12:13 PM
MAXRB8's Avatar
Gold star for the guys who figured it was the alternator
Old Jun 16, 2004 | 12:55 PM
NmexMAX's Avatar
dot dot dot ...
My bad, you guys get all the cool stuff. . .like VLSD. . .
Old Jun 16, 2004 | 03:17 PM
ch13f's Avatar
There was a recall on 97' alternators... might be a good idea to call up the dealer, cause I know a lot of guys had them replaced for free... including myself
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
