wow bling blings all over
Old Jun 22, 2004 | 06:44 AM
maxcooldc's Avatar
Ok i am not a newbie , but i have looked in the "How to" forum and every sticky but can't locate the write up on how to pull the codes for the airbag
Problem: My airbag light keeps blinking, I tried resetting it using the method in the "how to" forum but the #@$% light will not stop blinking i even disconnected the battery for 15 min but still that light keeps coming back.
Cause: Unknown, it all started after i put in my indiglo gauges. before that i did not even know that the airbag light exsisted
so can someone tell me how to pull the codes for the airbag, and also what the codes mean (list of codes) thanks
Old Jun 22, 2004 | 06:50 AM
maxcooldc's Avatar
bump.................
Old Jun 22, 2004 | 06:52 AM
shibbys's Avatar
how does the thread title relate to the topic? just curious
Old Jun 22, 2004 | 07:05 AM
maxcooldc's Avatar
attention grabber
Old Jun 22, 2004 | 07:24 AM
Seximus Maximus's Avatar
kinda worked.....
Old Jun 22, 2004 | 07:25 AM
maxcooldc's Avatar
so can anybody help me on this
bump
Old Jun 22, 2004 | 08:22 AM
jargoone's Avatar
bump
Yes. Try putting the subject of your post in the subject of your post. You're attracting the wrong kind of attention.
Old Jun 22, 2004 | 08:52 AM
Midknight MAXX's Avatar
The SES light and the airbag light are reset differently. The air bag light has nothing to do with the ECU. Did you do this?
Originally Posted by kevlo911
How to reset SRS(air bag) light –
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
Old Jun 22, 2004 | 09:40 AM
95stillenmax's Avatar
dude if you follow the exact directions off of the how twos it will stop blinking it worked for me
spazma7ik
Jan 12, 2017 09:38 PM
Finkle
Sep 27, 2015 09:53 PM
Maxx Atlanta
Dec 3, 2000 08:52 PM
Chebosto
Nov 13, 2000 05:12 AM
