Starting problems, acts like the battery is dead
Old Jun 23, 2004 | 06:36 AM
lsatch64's Avatar
I have been having an on going starting problem. It acts like the battery is dead. I can turn the switch four or five times and it will then start. It acts like the battery is dead. I replaced the battery and the grounding strap. I also had the starter rebuilt. I then replaced the electrical part of the switch. It still wont start unless I flick the key switch three or four times. I can jump across the solonoid and it will start every time.
Does anyone know if there is a relay for the starter and if so were it is? Or if you have any other suggestions it would be greatly appreciated.
Thank you
Lance
Old Jun 23, 2004 | 06:38 AM
lsatch64's Avatar
starting problems on a 95SE
[QUOTE=lsatch64]I have been having an on going starting problem. It acts like the battery is dead. I can turn the switch four or five times and it will then start. It acts like the battery is dead. I replaced the battery and the grounding strap. I also had the starter rebuilt. I then replaced the electrical part of the switch. It still wont start unless I flick the key switch three or four times. I can jump across the solonoid and it will start every time.
Thank you
Lance
I forgot to mention that this in on my 95 SE.
Lance
Old Jul 9, 2004 | 04:52 PM
bhmax's Avatar
Any luck? Similar problems on my friend's 95 SE.
Old Jul 9, 2004 | 05:28 PM
myke321's Avatar
Same here on my 96, i turn the key and nothing happens. After a few time starts up and happends once and a while.
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
Balkins
Feb 1, 2016 12:45 AM
Tha'-Max
Aug 30, 2015 01:14 AM
Samedi
Aug 13, 2015 04:05 PM
