weak stearing response
Old Jun 23, 2004 | 10:07 PM
ogparjay's Avatar
I have spring lowering springs and koni yellow setup. For camber issue I added camber bolts. Does the camber bolts affect my alignment and steering response because on turns the steering feels soft and not responsive enough.
Also how do you know what exact angle to position the strut assembly when you insert the camber bolts? And how much torque should I use? Because everytime I try to correct it it messes up again.
Help me out.
Old Jun 24, 2004 | 02:07 AM
njmaxseltd's Avatar
You need to have your alignment set after a suspension install.
Once it's set up correctly your steering response will be much better.
Old Jun 24, 2004 | 06:06 AM
ogparjay's Avatar
that's what i did, I guess the bolts were not torqued correctly. I'll do it again. Thanks.
spencerwh1
Jun 30, 2016 05:44 AM
Sep 27, 2015 08:37 AM
zmcneely13
Sep 26, 2015 02:26 PM
