My car failed emissions
Old Jun 24, 2004 | 10:08 AM
maxedout95's Avatar
I have a aftermarket exhaust. I was wondering if I switch spark plugs and see if I can get new O2 sensors If I can pass cause last year I had the same setup and my car passed.
Old Jun 24, 2004 | 10:21 AM
maximomo's Avatar
Are you getting any CEL codes? If you aren't getting 02 Sensor codes it's unlikely they are the cause of the failure.
Plugs may help a little. I'd check all of your vacuum lines for leaks, take apart your air intake and give your intake and TB a good cleanup. Put in a new air filter and make sure your intake connections are all tight when you put it back together.
Also, change your oil and run 5w-30 with a can of Seafoam in it for a couple hundred miles before you retest.
If you do have 02 codes then you should do the cleanup stuff B4 you replace the sensors. That way none of the crap in your engine will end up in the new sensors.
It can also help quite a bit to put some of that G44k fuel system cleaner in your tank. US detergent additives in gas are crap. They cause more injector spray pattern failure than even the dirt will. A good gas detergent additive will correct this in a couple hundred miles.
P.S. I have a 95 and had to go through all of this stuff to get mine to pass last year.
Old Jun 24, 2004 | 01:00 PM
MrRogerStatus's Avatar
VQ Disciple
I have a place raceing CAI, you think i'll be able to pass inspection?
In the stickies it said it should not be a problem, but i just had to ask.
Old Jun 25, 2004 | 10:47 AM
maximomo's Avatar
A CAI will not effect emissions if it was installed properly.
In fact, a CAI will actually reduce emissions if you are running premium gas and keep everything else tuned up right.
Old Jun 25, 2004 | 11:43 AM
MAXRB8's Avatar
How many miles on your car? Did you change your CAT when you added the exhaust?
Old Jun 25, 2004 | 11:48 AM
jkklim's Avatar
10char
Old Jun 25, 2004 | 11:51 AM
stephenlc's Avatar
They have to tell you why you failed and you have 15 days to fix it free of charge. Tell them to give you printout and ask them what is wrong
Old Jun 29, 2004 | 05:22 AM
maxedout95's Avatar
[QUOTE=maximomo]Are you getting any CEL codes? If you aren't getting 02 Sensor codes it's unlikely they are the cause of the failure.
The only code that comes up is the Knock sensor. I have over 184,000 miles on my car.
Old Jun 29, 2004 | 06:48 PM
Rowan's Avatar
how about 5th gen muffler with Warpspeed y? Will that pass emissions? (assuming it's warmed up fully)
Old Jun 30, 2004 | 05:45 AM
maxedout95's Avatar
I have the random cat with the whole exhaust system from warpseed.
Lakersallday24
Jun 16, 2019 01:35 AM
PH98I30
19
Jun 13, 2016 02:38 PM
laparka66
Aug 6, 2015 09:36 AM
yat70458
Aug 3, 2015 01:16 PM
