Skipping gears with manual bad?
Old Jun 24, 2004 | 11:54 PM
99maximase's Avatar
Is skipping gears, like going from 2nd to 4th, bad for ur tranny for any reason?
Also, I often drive in 5th other than on residential streets. I now have a problem shifting into 5th, if the rev is too high it grinds. Is this because 5th gear has been used to much? Is it bad to "over use" 5th gear?
Old Jun 25, 2004 | 08:22 AM
Brudaddy's Avatar
No.
No.
and No.
Skipping gears should not be any problem, unless you are forcing the stick into the gear when the rpms are not lined up correctly. This will cause your syncros to go bad, and you will not be able to shift into some gears. It should not be a problem though.
5th cannot be used too much, I don't think. I have a 99, and my car is like new.
You sound like you are forcing it into gear at the wrong rpm. When the rpms are correct for that gear, the stick will just fall into place with light pressure. You should not have to force it.
Old Jun 25, 2004 | 08:45 AM
a_prince1's Avatar
skipping gears is not bad. Drivers do it if for example if in second gear you have taken the rpm too high switch to fourth to even out rpm with tranny gearing. Because putting it in third would make the car bog and you would loose some momentum.
5th gear is overdrive / lowest friction gear. No way driving on it would be bad. If its grinding try to press the clutch all the way in. That usually works for some people.
Old Jun 25, 2004 | 09:07 AM
Brudaddy's Avatar
Some truth. However, some non-truth.
"putting it in third would make the car bog and you would lose some momentum"?????? How could this be? I mean, putting it in 4th from 2nd would make it bog, not in third.
Also, if you bog 5th, it could be bad for the car. I don't think it would be bad for the tranny, but it would not be the greatest for your car.....mostly just gas mileage.
Old Jun 25, 2004 | 10:03 AM
MrEous's Avatar
^ Jeff™
FYI...Corvettes/Camaros/Firechickens have a Skip shift installed from factory.
What this Skip shift does is shift from 1st to 4th if the revs are too high.
Old Jun 25, 2004 | 10:20 AM
Pearl99GXE's Avatar
That Skip shift is based on throttle position not revs. If you are flooring it, it won't skip the gear. If you are driving lot Granny then the skip shift feature kicks in.
Old Jun 25, 2004 | 10:36 AM
MrEous's Avatar
^ Jeff™
d'oh...You're right.
Old Jun 25, 2004 | 03:30 PM
95stillenmax's Avatar
how could it be ????????????????????
Old Jun 26, 2004 | 01:41 AM
99maximase's Avatar
The problem I am having with 5th gear is a wear problem, because I didnt have it before. Basically, if I shift into 5th and the rpm is about 3k, it will grind. So when I do shift into 5th, I just leave it in nutral until the rev gets down to idle then shift. Other wise it grinds. I think I may need to change the gear lube which leads to a new question. Are you suppose to change the gear lube and if so after how many miles? From the factory, the lube is sythetic right?
Old Jun 26, 2004 | 05:58 AM
Bobo's Avatar
Are you talking about transmission fluid? I don't believe its synthetic from the factory. I think it should be changed at around 60,000 miles. My manual doesn't recommend a change interval, just periodic inspection of it.
I don't think fluids are your problem.
Old Jun 26, 2004 | 06:02 AM
MAXRB8's Avatar
Sounds more like your syncro's are on the way out, you may want to consider a tranny rebuild maybe when you eventually replace the clutch.
Old Jun 26, 2004 | 08:45 PM
99maximase's Avatar
how much would that cost me?
Old Jun 26, 2004 | 11:32 PM
MrGone's Avatar
No its not bad, i do it all the time. Leaving my neighborhood I normally go 1-2-4 or so.
The last gen f-bodys/vettes do the 1-4 shift thing for improved city mileage.
as others have said, the 5th gear thing could be worn syncros
Old Jun 27, 2004 | 06:35 AM
Blackwind's Avatar
when i drive normal it 1-2-4 till i hit the on ramp then its 4-3-5 as long as you dont grind or ride the clutch youll be fine.
Old Jun 27, 2004 | 03:42 PM
95BLKMAX's Avatar
Don't know about syncros for the Max, but my friend's 95 Altima need new syncros for 3rd and 4th gear and they go for $60 each from the dealer. Just so you have a reference as to how much they are more or less.
Old Jun 29, 2004 | 09:06 AM
99maximase's Avatar
thanks guys,
do you know how munch an install would be? i should just call the dealer....
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
pjgreek
Sep 9, 2015 09:30 PM
pktaske
Sep 4, 2015 08:40 AM
