Question about gauge faces
Old Jun 25, 2004 | 04:22 AM
cheffswann's Avatar
I am about install a set of glo-gauge faces this evening. I noticed currently there are two nodules on the tach & speedo that the gauge needles rest on when the car is off. But the new faces don't have holes for these. Can I break these nodules off. Do I need to put holes in the new faces? If I do break these off, will the needles fall and point down?
Just got my max a few months ago and I'm trying to dress it up a little. Any assistance would be welcome.
Old Jun 25, 2004 | 04:31 AM
Nismo's Avatar
I see what you mean, but I think the needles will sag like you said. probably should drill a hole but im not shure if that would effect the indiglo or not
Old Jun 25, 2004 | 04:36 AM
cheffswann's Avatar
Thats what I'm woried about. I don't want to screw up the faces, but i'd rather f*** those up than the actual instrument panel. anyone out there done this?
Old Jun 25, 2004 | 05:00 AM
Nismo's Avatar
maybe you should sell those and buy these http://cgi.ebay.com/ebaymotors/ws/eB...category=43952 since they have the holes. I would just drill the holes anyways though
Old Jun 25, 2004 | 11:49 PM
MyMaxRocks96's Avatar
They have the holes, but not the ones where the screws holding the entire thing down were, for instance in the speedo the screws on either side of the odometer cutout, there are no holes for them, meaning that whole bracket is somewhat loose. And with that the faces are elavated, causing the needles not to move, trust me, i just spent a few hours cursing at them to work.
Unsure whether or not to drill holes because that might screw up the indiglos...
Old Jun 26, 2004 | 03:56 PM
MIXXMAX's Avatar
Buy the indiglos with the needle rests holes already pre-drilled. It doesn't really matter if there aren't any holes for the gauge mounting screws. These screws just hold the actual face on. It makes the face move once the screws are removed, though. What I did, when I had indiglos in my '95, I had to remove the gauge mounting screws. But, once they were removed, I had taped them down along the outside diameter to keep them from moving, and then I had mounted the indiglos on top of them. Never had a problem with them after two years of having them installed before I got rid of the car.
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
